Hello there. I would like to start with a quote from the new earthquake regulation; 3.6.1. Simplicity and Simplicity of the Structural System Due to the uncertainties in earthquake ground motion, structural modeling and structural element behaviors, as well as approximations in analysis and design methods, the basic rule of design under earthquake effect is that the structural system should be as plain and simple as possible in order to ensure that the earthquake behavior of the building is predictable. . Here, the general approach in terms of carrier system design is described. While making this description, it is mentioned that the earthquake and the reinforced concrete system cannot be calculated exactly and approximations are mentioned. For this, the aim is to design a system that is as simple and predictable as possible. In your system, there is not even a frame connection between the columns. Another beam connection is made from the critical column-beam junction area, where the support moment of the beams is maximum. Moreover, another beam is connected to a cantilever beam. There is a fact that I did not know in the first years of my career, but I learned and experienced later on, and every civil engineer must understand this; The design and calculations made in our profession are not final results! This approach may be correct in other disciplines. In computer programming, for example, everything is clear and works exactly as it should. A deviation in the number in the 10th digit after the comma will cause the system to not work correctly or not to work at all. Our job is 'the art of making real structures under the influence of undetermined loads, using materials whose properties can only be predicted, whose properties can only be analyzed approximately.' While saying this, I certainly do not mean that the analysis and calculations we make do not matter. Those accounts should form the basis of the design. Otherwise, the science of engineering will not matter. The important thing is the ability of the engineer to comment and criticize the design made as a result of these analyzes and calculations. Therefore, there are general principles of designing simple and predictable systems as a result of engineering researches, calculations, experiments, experienced earthquakes, knowledge and experience. Programs, on the other hand, help us calculate the most realistic results possible in this complexity, and help the engineer to think over and analyze the design. To this end, they make our work much easier. What the engineer should know is that static and dynamic analysis programs are almost an advanced calculator used by the engineer. Programs transform the system we enter in 3D into a mathematical model within the framework of some assumptions. The engineer should know the general logic of this mathematical model and ensure that the data he enters conforms to this model. Responsibility and control always belong to the engineer. My humble advice is to ensure framing continuity, far more important than architectural concerns, and not use joist studs near the column-beam junction. In addition, minimizing the A1 irregularity and keeping the relative floor drift around 0.01 will enable you to design regular and rigid buildings.
