beamless slab stapling rope output problem
cesuray
friends, in the attached project, I can't see the results of stapling of uncreased floors in the ropor output. I would appreciate it if you could help.
Levent Bey, I can't get the results for the plate wicker floor, I can't enter the column title, is there something I'm missing, I don't understand, thanks
"cesuray":103b7ig8" said:
levent bey I can't get the results for the plaque wicker floor I can't find the column header is there something I'm missing I don't understand tskler
I think you are talking about the columns numbered S5-S16-S17-S20 sitting on the floor. To do this, place the column header under the columns with the height and table height zero.You can see the results in the Staple control section of the Floor Report
yes, levent, thank you, by the way, I knew that ide 7 did the stapling controls automatically without entering the header, I have a project in hand. It gives the results of stapling on the floor without a broken column header with the floor without a table, beamless 7, as a report.
"cesuray":1n4lbrbf" said:
evt levent bey thanks, by the way, I knew that ide 7 did the stapling controls automatically without entering the header, I have a project in hand. ] When the slab borders are created with the slab edge, that is, when the beam is not used, stapling control is done automatically.
"Levent Özpak":1ev3upnr" said:
"cesuray":1ev3upnr" said:
levent bey can't get the results for the plaque wicker floor, I can't enter the column header, is there something I'm missing, I don't understand tskler
I think I'm sitting on the floor Q5-P16- You are talking about columns S17-S20. To verify staples on these columns, place a column header under the columns so that the height and table height are zero. You can see the results from the Staple control section in the Tile Report.
Hello, It's been a long time since the topic, but I have a question, why do we get the table height as 0? Since the slab thickness is 20, shouldn't we get 20? Also, is 150x150 a standard size? I will be glad if you answer. good work
the table height is the table height of the column head, if you look at it in 3 dimensions, it becomes more understandable if you examine it a little. Also, if the table height height and elevation options are to be made on site, it is necessary to define it.
"Reform Group":2h2w5kbi" said:
"Levent Özpak":2h2w5kbi" said:
"cesuray":2h2w5kbi" said:
levent bey can't get the results for the plate wicker floor, I can't enter the column header, is there something I'm missing that I don't understand?
I think you are talking about columns numbered S5-S16-S17-S20 that sit on the slab. To verify staples in these columns, place a column header under the columns so that the height and table height are zero. You can see the results in the Stapling control section of the Floor Report.
Hello , It's over the top of the subject, but I have a question, why do we take the table height as 0? Since the slab floor thickness is 20, shouldn't we take 20? Is 150x150 a standard size and I would appreciate it if you could answer it. Good work
Hello, The purpose here is just stapling Column header is placed because it is to control.Therefore, height and table height values should be entered as zero.
