mkarakose79
Hello, in the beamless slab school project, can we divide the corridor and classrooms by the slab edge because of the live load difference? Or do we need to make a single beamless slab? When beams are not desired on the exterior as well from an architectural point of view, I cannot fix the punching error in the exterior columns when we use staple reinforcement from the column properties, if we are going to make beams on the exterior, since the thickness of the floor without beams is 30 cm, the beam height must be 90 cm according to the regulation. Can we make the height of these beams 60 cm? ? I would appreciate it if you could examine my attached project and give information, Good work.
Log in or register now.
