Beamless floor stapling verification
ytu_ytu
Hello; I modeled the attached project as a beamless slab. However, after the analysis, it seems that punching verification is not done in some curtain elements. Is there a mistake? If there is no error, how can I verify the punching in these elements? In addition, is it necessary to check the punches in the column/wall structural elements in the outer contour, which are connected to each other with beams? I could not find it in TBDY 2018, but in the ACI regulation, it is stated that there is no need for punching verification in case of connecting with beams. Thank you.
"ytu_ytu":2c8xd8jl" said:
Hi, I modeled the attached project as a beamless slab. However, after the analysis, it seems that punching verification is not performed on some shear walls. Is there an error? Is there a need to check for staples in the column/wall structural elements in the outer contour?I could not find it in TBDY 2018, but in the ACI regulation, it is stated that there is no need to make a staple verification if they are connected with beams. if it is not connected but stapling verification has not been done, if you attach the project file, we will review it.
