beam?
It does not define the beams to pass over the panels. Since the panel object has two nodes, the K01 beam must be connected to the P01 panel from the upper node. Anchor reinforcement lengths are the same for both beams in beam expansions.
there is no problem with the anchor, I meant the amount of reinforcement, I made a small comparison in the folder below, can you check it?
"kth10":32t61ujh" said:
there is no problem with anchorage, I meant the amount of reinforcement, I made a small comparison in the column below. It is modeled as a shell and the beam rigid arms are different.
