Have a nice day; When you look at the projects, they usually take two stable values for the exterior and interior walls, but when you look at the interior walls, for example, the beams carrying the door and window must be able to enter much smaller wall load, or there are too many parts of the beams that come to the floor rather than the wall... Of course, for these beams. Since it is difficult to calculate separately with detailed moving and wall loads, for example, in my current project, I was told 20 cm pumice walls for the exterior and 20 cm bricks for the interior rooms. Will the wall load of 0.8 tf/m be entered for a 19 cm brick for a 20 cm brick wall? Also, there is no wall load for pumice in the options, is pumice a kind of brick? What is the beam wall load for 20 cm pumice wall? Also, is it possible to mark the beams divided by studs piece by piece with ctrl and enter different values?
