Beam Wall Loads
hkderinoz
Member
Can you give a more detailed explanation about the beam loads in the load library in the program as seen in the related annex? When we want to enter a new beam wall load, for example, it can be a stone wall. How should the properties of this material (unit volume weight, etc.) be entered? It may be in different instances. Thanks...
If you press the F1 key while the load library dialog is open, you can access the explanation information about the subject. Also, follow the thread I linked below. The content of the subject and the template project will be an example for you.
Good work
