it gives br error on beams. I think it's due to torsion. The only solution is to enlarge the section. is there any other solution? I was thinking that torsion could be prevented with body reinforcement, but I did not understand why it did not. can you help
I couldn't add 9 mb or something. It says (Br) next to the beams. In the report, it is written that the beams are insufficient in terms of torsion.
You can give partial rigidity to the beams showing torsion. Also, if you say file -save by compressing to reduce the size of the project and add it here, the file size will decrease.
If your beam makes conformity torsion as per TS 500. Check the "Conformity torsion check" box in the settings for this beam. In multi-storey structures, side beams and beams supporting simple beams often do conformation torsion.
