In hollow block systems, the width of the beams is generally larger than the width of the column. Leaving aside the regulation criteria and calculations such as 1.2 times the moment capacity, what are your engineering predictions about whether both dimensions of the beam are larger than the dimensions of the column, and if this situation occurs in beams connected to the column from four directions? For example, suppose 60/40 beams are attached to the 60/35 column from the 4 direction. Thanks.
