Beam shear safety
Hello My suggestions; --Remove the DS ticks on the beams, --You can't solve it because there is no curtain in both directions, mixed and limited. Get high RX=8 Ry=7, --C13 and C24 columns (B) error occurs, edit the column sizes, --According to the warnings above The corrected DEMO project is attached, --When the elective reports are received, there is an error in the floor landing floors where the stairs sit, --Do not leave a single console from the column, (C001-C006 columns) --It would be better if you place the K81 and K86 beams on the column, which is stuck very close to the column. Unver ÖZCAN
also, it seemed safer to exit the console from the c001 and c006 column because the consoles that I exited in the corners would not be better to come to the column.
Hello
"orhan gunay":27jk6oz1" said:
I couldn't find how to fix the stair landing problem
For solution, thicken the landing floor, if not, change the landing modeling,
"unver":27jk6oz1" said:
--When selective reports are received, the staircase sits There are errors in the floor landing floors, fix it,
If you click on the red arrow in the ADDITIONALS, you will see the wrong ones,
and it seems safer to exit the c001 and c006 column because the consoles I exited at the corners do not come to the column. Wouldn't it be good
No way, remove these consoles Unver ÖZCAN
