Beam shear safety
hatice.mert
hello in my project, my k334 beams give shear safety error on all floors, I can't understand. Previously, the s333 column on the left side was 60 and there was a stud on the beam. But in this case, the cutting error did not occur. When I enlarged the column to prevent the stud, this error started to appear on the beam.
"hatice.mert":1zscwu7t" said:
https://www.dosyaupload.com/a8c4 hello in my project, my k334 beams give shear safety error on all floors, I can't understand. Previously, the s333 column on the left side was 60 and there was a stud on the beam. In this case, there was no cutting error. When I enlarged the column to prevent the stud, this error started to appear in the beam. I would appreciate your help
Hello, the problem in the K34 beam seems to have arisen from the incorrect arrangement of the stair supports. It should be determined that it is attached to the element, the edges that are not supported on the carrier element should also be left blank. In your project, the idle edges of the ladder are arranged as a fixed support. You can watch the training videos on the following links about creating the ladder and determining the support conditions.
Good work
"Levent Özpak":1bwly6s8" said:
"hatice.mert":1bwly6s8" said:
https://www.dosyaupload.com/a8c4 hello in my project, my k334 beams give shear safety error on all floors, I can't understand. The s333 column on the side was 60 and there was a stud on the beam. But in this case, the cutting error did not occur. When I enlarged the column to prevent the stud, this error started to appear in the beam. I would appreciate your help
Hello, the problem in the K34 beam seems to be caused by the incorrect arrangement of the stair supports. While determining the support conditions for the solution together with the structure, it should be determined that the edge of the stairs is connected to the element that is supported, and the edges that are not supported by the carrier element should be left blank. In your project, the free edges of the ladder are arranged as a fixed support. You can watch the training videos on the following links about creating stairs and determining the support conditions.
Good work
Mr. Levent, I fixed it as you said, but this time I get nmax error in different beams and absurd dimensions save. I added the project. k231 and k255 beams give nmax error, s106 column punching error. can you help?
