Beam scan problem in plans
dester
I wish you a good day. I installed the 6.2 version, my question is, when the template is getting the plan, the crosses come out like they are when entering the system. For example, my beams stay green and the blueprint comes out with a green hatch. Previously, only the beam line was coming out. Deleting scans afterward is tedious. I will be glad if you check it out. have a nice day
Hello, In the previous version it was not shown in the formwork plan even if scanning was defined on the beam. We've made scans visible for those who want to use them in V6.2. However, if you don't want to see the beam hatches as you wrote in your message, turn off the "beam hatch" sublayer in the layer settings "drawing details" tab before importing the mold plan. You don't need to delete the scan every time... Good work...
6.02 requests Hello, thanks to everyone who contributed to 6.02. I will have a few requests. There is a problem with the section in version 6.02. When I cut the attached project in 6.01, there is no problem, but in 6.02, the sections are very bad. I will be glad if you check it out. Also 1) The latest situation regarding beam scanning in plans is not useful at all. It is a waste of time to make adjustments to the layer settings separately for each floor while getting the pattern plans. Instead, an option can be put in the mold plan drawing properties menu. Thus, by activating this option, one can print out the beams as scanned. 2) While the column reinforcements are being discarded, more reinforcement is found on the upper floor than on the lower floor. (You can see this problem in the attached project.) In such cases, it would be better if the program assigns the amount of reinforcement on the upper floor to the lower floor. Good luck with.
Hello, Section and scanning issues will be addressed in the update version. Your request regarding column reinforcements will also be noted in the work list. Thanks...
