MustafaAkın20
Hello, my question, when I examined the report of the beams, I saw that there are combinations with the capacity ratio greater than 1 (such as 1.021,1.008) in the capacity design. It appears in the effect diagram as well. This capacity ratio must be the shear force and moment relationship. If this is the case, the beam did not issue a capacity warning. Am I interpreting it wrong? I would be glad if you help. Good work.
