*I delete the additional reinforcements of the ground floor k6 beam from the reinforced concrete-beam-beams tab. When I click on the beam name from the reinforced concrete configuration, the change I made in the beam reinforcements is not processed. Beam reinforcements appear to be added as before. Also, the reinforcements that I deleted in the reinforcement fields tab are not processed. *k5 and k6 beams are continuous. In the reinforced concrete -beam tab, when k5 beam is selected, when I change the top right or bottom right reinforcement from the reinforced concrete configuration, the addition in the k6 beam does not change automatically. It stays in its old state, which causes the reinforcement areas to be incorrect. *I didn't send the file, you can see it with a simple beam modeling. Reinforced Concrete - Beam tab is not working properly.
