My friend, Here 7 chapters of TDY regulation for performance analysis of existing undamaged Structures were published in 2007. It is not correct to use the analysis section of 2007 regulation for structural reinforcement. Model this structure in version 6.51, enter the reinforcement and material properties of the existing structure Perform a performance analysis. In the regulation, advanced damage is allowed in 30% of beams. This rate is 20% (according to shear capacity) in columns. Here, instead of improving on element basis, the method of reducing the lateral loads on the elements with additional wall elements that will take the lateral loads should be used. It is not correct to say that these elements have deflection and strengthening on the basis of elements is not correct. Particular attention should be paid to beam sheathing. It should not break the strong column rule. The performance analysis and strengthening logic is very different from the normal building analysis logic. Ide 6.51 version is currently the best program in the market that does this analysis. ( METU Master's Degree This result emerged in my thesis.) As a result, first make a linear performance analysis of the building. If the performance is insufficient, general structural improvement should be made in the brittle elements and additional bulkheads throughout the building after strengthening. But all the analysis we do should be structural performance analysis, not normal structural analysis. Greetings Suat
