good work. In my project given in the attached link, the amount of reinforcement for K40 beams on normal floors seems very low to me. Is the reinforcements thrown into this beam sufficient, including the loadings from 20-inch wall stud beams and elevators?[/quote ] According to the support and span moment values in your beam, there is no problem in the amount of reinforcement.
"yilmaz polat":2s9fnco7" said:
and this beam, which is between K39 and K41, does not constitute continuity although it continues at a very small angle with the K39 and K41 beams. . Does this cause trouble? Are the thrown reinforcements sufficient for this beam, including the 20-inch wall stud beam and the loadings from the elevator?
çelebi_16.03.ide7.html
Small tee between K39- K40- K41 beams There is an angle difference though. In the Reinforced Concrete / Parameters / General Reinforced Concrete Parameters dialog, you can accept beams continuously by entering an angle value (for example, 5 degrees) in the "Continuously accept beams with small angle difference" line. Note: *Some of the S20 column and P4-P5 panels in the basement floor are outside the raft slab. left.
