Beam Reinforced Concrete Reinforcement Areas
MustafaAkın20
Hello, after the analysis, available-required-excess reinforcement areas appear as 0 (zero) in the beam reinforced concrete reinforcement areas section. The torque values are displayed. and makes the necessary design. I've looked at all the beams but none of them show any reinforcement area. Where is the problem? When I click "Hardware Calculator" in the same menu, it gives an error "Failed to run ascalc.exe" and does not work. Thanks.
Hello there; As long as you don't share a model, the only answer we can give is "no we haven't met". Best Regards.
"MustafaAkın20":2lrvtbkk" said:
I am adding the project...
Beam reinforced concrete - Reinforcement areas - right mouse click on the zero point - cm option on the opened screen Or building tree - design - design settings - mouse right click - reinforcement - cm - ok
Thank you Mr. Şahin, after making a right click and making cm, the equipment appeared. mm was visible in the design settings. I corrected it to cm and analyzed it again, but it still showed 0. It appeared again when I right clicked and made cm. Calculator still doesn't work :).
"MustafaAkın20":35hf8xoh" said:
Thank you Şahin Bey, when I clicked right and made cm, the reinforcement appeared. In the design settings, mm was visible. I corrected it as cm and analyzed it again, but it still showed 0. When I right clicked and made cm, it appeared. Calculator still doesn't work :).
The accessory calculator works for me too.
"MustafaAkın20":1nzm3f0s" said:
Thank you Şahin Bey, when you right click and make cm, the reinforcement appeared. In the design settings, mm was visible. I corrected it as cm and analyzed it again, but it still showed 0. When I right clicked and made cm, it appeared. Calculator still doesn't work :).
You can also benefit from here.
"MustafaAkın20":uzikx1pm" said:
The error message is attached.
Can you check if the "ASCALC.EXE" file exists under the C:\Program Files\ideCAD\ideCAD Static 10 folder? It will solve the problem. If there is a file, try to run it by double-clicking it. If it doesn't work, call our Bursa office and leave your contact information. Let's examine the problem by connecting to your computer remotely. Good work
