Beam raft drawing
uzuncayir
In the project at hand, the foundation is not suitable for the definition of continuous foundation (due to the ground settlement value) and I cannot overcome the stapling problem in 6 columns when I make a raft foundation. All that was left was to make a rafter raft, but I looked at the drawing of the rafter raft in the idea and could not find any sharing. I would be very happy if it helps. Finally, sta4cad also throws beams in both directions under the 50x50 or 60x60 column into the raft for columns with punching, is it possible to apply this in the idea?
Hello. I couldn't find a post.[/quote] Type "beam raft" into the search box on the top right and search,
"uzuncayir":1gtkw4pl" said:
Finally, for columns with stapling in sta4cad, a 50x50 or 60x60 column can be inserted into the raft in both directions I wonder if we can apply it in ide
Ide takes the punching with concrete. If it doesn't, you need to increase the concrete height and/or the concrete value. Unver ÖZCAN
Hello,
for columns with stapling, beams are thrown into the raft in both directions under the 50x50 or 60x60 column, is it possible to apply this in the ideal,
In order to overcome the stapling problem, you can define a continuous basis in the program to connect several columns. (If it is desired to obtain a flat surface on the ground, the rafts can be defined at the same level as the continuous foundation.) Other columns should be divided by the raft edge. Reinforcement type should be edited as "top + bottom flat reinforcement" with the Reinforced Concrete Calculation axis edit command for raft reinforcement axes. - In the rafter raft foundation system, columns and walls are connected to each other with continuous foundations. A raft is placed on the eyes formed in between.
"uzuncayir":1qy5g0ft" said:
Unfortunately, nothing about rafter raft can be found in the search section
You can find information about rafter raft definition by searching the F1 help menu about rafter raft. https://www.idecadsupport.com/forum/search.php?keywords=kiri%C5%9Fli+radye[/url]
