Hello, It can be used to change the free/fixed state of the left and right ends of the beam. You can change these parameters, which do not need to be interfered with in normal situations for the design in accordance with the regulation, by ticking the option in the relevant direction when you need it. i is the left end of the element, j is the right end of the element. The larger the spring value, the less displacement the relevant end will be. You can interfere with the values on the appropriate axis of the parameter you want to change. For example, when you want to operate the beam in a hinged way, we click on the i and j freedoms in the moment m2 and m3 directions. When you want to give the beam axial freedom, we click on the i and j freedoms in the f1 directions. If we enter the spring value after activating the freedom, we define the spring as much as the stiffness value we entered.
