1-) While K5 divides the beam as K29-K30, why does the K6 beam not divide the K36 beam? K5 beam and K30 beam must be split so that D348 and D353 slabs can be defined correctly. K6 beam is not divided into K36 beam because "divide by intersections" mode is not active. Splitting beam is done to create a slab corner at the inserted beam(divider) and bearing beam(dividing) point Floor edges are formed from the corners Splitting the beam does not affect the analysis, it is only a process related to data entry
"huseyinakkus56":xjxe9ceg" said:
2-) How to join the beam? (I also split the K36 beam because I faced the problem of not being able to assign slabs; it self-assembled).
Since the K6 beam and the K36 beam are not connected to each other, the K36 beam seems to be one piece. In order for you to correctly identify the D351 and D350 slabs, the K6 beam must divide the k30 beam. If you delete a dividing beam from a dividing beam, you cancel the joint, which will self-join as you did. You've probably done something like this.
3-) Although I pay attention to the nodes, I cannot assign tiles. As a solution, I have to divide the beams or curtains, otherwise I cannot assign tiles. Where can the problem come from? .
The answer to this is 1 and 2 The reason for your slab assignment is that the definitions of the inserted beam (divisor) and the bearing beam (divided) are incorrect. Activate the "divide by intersections" mode when defining the K6 beam. The same situation is wall-beam, beam-slab edge, curtain-continuous foundation, It is also valid for continuous foundation-floor edge, slab edge-floor edge combinations.Note: After the 8.5 version, the program has no longer required such data entry (split).The program handles these works automatically.
