Beam Nmax error and Reinforced Concrete Movie Theater Design Help
vtutkal
Good afternoon, how can I design the section where the movie theater is located in the 1st basement in the idecad family 1-School project. (I showed the section where it is by drawing a ladder.) 2-1. In the basement, I could not fix the faults in the beams around the ladder (Beam exceeds Nmax). Can you review my project and tell me what's missing? Thanks in advance for your help.
Re: Kiriş Nmax error and Reinforced Concrete Movie Theater Design Ya Hello
"vtutkal":281brvq7" said:
1-How can I design the section where the movie theater is located in the 1st basement in the school project (I showed the section where it is by drawing a ladder. )
--It is difficult to comment unless we know what the movie theater and adjacent classrooms are on the upper floor,
2-1. I could not fix the faults in the beams around the stairs in the basement (Beam exceeds Nmax). Could you examine my project and tell me what I'm missing?
--You entered the curtains as columns, enter them as curtains, --4. give the floor slab loads like the 3rd floor slab load, --Remove the wall load on the beams in the corridor, --If this is the school, the wall on the outer beams is not up to the ceiling, you can reduce the wall loads, --Fix the support of the stairs, remove the wall loads of the beams sitting on the floor, --After doing these Then if the beams in the basement do not recover, you enlarge them, --You correct the last B errors, --There are very few minus areas in the raft base in this modeling, but the correct modeling can be corrected. Ünver ÖZCAN NOTE: There is very little time left for the implementation of the new earthquake regulation. I suggest you wait a bit and do the project according to the new regulation.
Re: Kiriş Nmax error and Reinforced Concrete Movie Theater Design Or What I said was for the part on the right. attached. For the step-shaped section, lay the bottom with stabilizer and compact it properly. Pour 10-15 cm thick stepped concrete on it. Put Q8/25 cm reinforcement in both directions between the concrete (show sprouts from the curtains) and detail this in the drawing. (You don't need to solve it like a ladder.) Ünver ÖZCAN
Re: Kiriş Nmax error and Reinforced Concrete Movie Theater Design Ya Mr. Ünver, I applied the corrections as you said. But now I'm having problems with basement curtains. Especially the curtains attached to the polygon column give an error. I would be very grateful if you could review and give your opinion. Good work
Re: Kiriş Nmax error and Reinforced Concrete Cinema Hall Design Or My suggestions; --Loads, beams, floors, stair bracings were arranged in the project. (Since extensive improvement was made in the V8 version.) The project is attached. Hopefully it benefits your business. Unver ÖZCAN
Re: Kiriş Nmax error and Reinforced Concrete Cinema Hall Design Either Could you please check the reinforced concrete design of the conference hall in Block B of Ünver Bey's school project? Is this the right design, what is your suggestion? Architectural Project is attached. Thank you for your interest.
Re: Beam Nmax error and Reinforced Concrete Cinema Hall Design Or Do not forget to enter the loads coming from the roof on the 3rd floor columns in the attached project proposal. Unver ÖZCAN
