Beam naming
cakilomer
In the system I sent in the attachment, should the beam naming be done separately or should it be as I sent it. Best regards
Re: beam naming ?
"cakilomer":37tqca0l" said:
In the system I have attached, should the beam naming be done separately or should it be as I posted, thanks. Best regards
You can decide the beam names by looking at the moment diagrams If K7 and K9 beam moments are positive at the point where K30 is connected, it would be appropriate to give the same name to the beam parts.
Re: beam naming ? Mr. Levent, can we only see - sides in the diagram, do we have the option to see only the moment diagram of that beam, where can I enter? Best regards
Re: beam naming ?
"cakilomer":c0x3b7u2" said:
Levent bey, can we see only the - sides in the diagram, do we have the option to see only the moment diagram of that beam, where can I enter? Best regards
Frame in Structure Tree If Moment 3-3 line is checked in the results line, beam moment diagrams can be seen. In addition, element-wise analysis can be performed by selecting the element in the perspective window and selecting "Show element results" from the right-click menu
