beam loads
fthylmz
In a simple trial study, when I dissolve the stairs together with the structure, 9 fixed and wall loads come to the beams. I also encounter the same situation in my project that I have been working on.
"ftthylmz":10uvlley" said:
In a simple test study, when I dissolve the stairs together with the structure, 9 fixed and wall loads come to the beams. I encounter the same situation in my project that I have been working on.
Hello, Load information on the beam on which the ladder is supported is pressed repeatedly due to the rigid arms that attach the ladder to the beam.
Thanks for your answer. In the report, I see that there is no load transfer to the beam to which the load of the ladder is attached. What is the reason of this?
"ftthylmz":1qd3kimr" said:
Thanks for your reply. In the report I see that there is no load transfer to the beam to which the load of the Ladder is attached. What is the reason for this?
In active versions, the loads from the ladder are not shown in the beam loads report.
