Hello, -The load indicated by number 2 in the beam loads report is not the stud load on the beam, but the load defined by the user on the beam. -The interaction of beam-to-beam intersections should be evaluated in terms of solution methods of 3D systems in the program. Loosening the studded beam and giving the stud load to the bearing beam is only an approximate method followed in 2D analysis. In this context, no approximate models are used in the program. Because true three-dimensional analysis is done, there is only one frame in the system. It is the building itself, and the beam-beam junctions are also included in this frame. As a result of the analysis, the end forces of each node point are calculated at once. Since beam-beam connections are a nodal point, only nodal balance can be mentioned in such connections. Therefore, an expression like stud load cannot be used in ideCAD Static. There is no such load, the balance of that point in terms of extreme forces is in question. Good work
