sonsamuray
Beam scan colors do not appear in the formwork plan, but the scans I made for columns and curtains appear on the formwork plan.
"Emrah YILDIZ":2lbjffb0" said:Hi, In order to avoid drawing confusion in mold plans, scanning is done automatically only on vertical elements. Why do you need beam scanning? If you want to see this hatching in drawings, you can draw it manually using the hatch command. Good work. [ /quote] Actually, I didn't need it. The approval agency wants everything in color when it checks over dwg. So it will see all the elements better. As you said, it takes a lot of time to scan them all. I changed the color of the border lines, it's okay for now. Thank you for your attention.
You can suggest that the approval authority try to make the background of the dwg program they have examined white or black"sonsamuray":aeh3oc7b" said:I didn't really need it. The approval agency wants everything colorful in its control over dwg. That way, he would see all the elements better. As you say, it takes serious time to scan all of them. I changed the color of the border lines, it works for now. Thank you for your interest."Emrah YILDIZ":aeh3oc7b" said:Hi, In order to avoid drawing confusion in pattern plans, scanning is done automatically only on vertical elements. Why did you need beam screening? If you want to see this raster in drawings, you can draw manually using the scan command. Good work.
