Beam expansions error
HulisiKayaci
Hello, take it easy. I can't see the beam expansions. It gives certain beams and some does not. Why could it be ? Thank you very much to those who are interested. I've seen the geometric controls, I'll fix them. I'm stuck on this part.
Hello, There is a situation where the spans of some beams exceed 12 meters... In the Reinforced Concrete/Parameters/General Reinforced Concrete Parameters dialog, type a value such as 1400 cm in the "Combine shorter reinforcements" line. (Or uncheck the line) Analyze. Do not forget to make arrangements for reinforcements exceeding 12 meters after taking the beam angles. Some other notes; D1-2-3-4-9-10-11-12 slabs boundaries are wrong (the edges of slabs are seen as panel objects. Delete and redefine slabs. Link beams on A-1-2 axes have incorrect elevation. Good work
