beam error in report
enciniir
hello friends, good luck to everyone, good luck. When getting a report in my project, 0000000 appears on the beam and gives an error. What could be the reason and how can it be fixed? I took a screenshot, I'm attaching it, if you can help me, I would be very grateful
"enciniir":kf4vj8sp" said:
hello friends, good work and good luck to everyone. When I get a report in my project, 0000000 appears on the beam and it gives an error. What could be the reason, how can I fix it? I've taken a screenshot, I'll be very happy if you can help here, thanks in advance
K17 and check the loads of the K19 beams and the floor connections.If you add the project we can look at the problem.
"HakanŞahin":2v0yaydy" said:
Hi, there is no such problem in the report in 5.503. You can download the update from the link below and start using it immediately.
when updating was done, some column beam slabs had errors, I guess, did you see any problems in my project, similar to this?
