beam drawings
fuatturan
Guys, I just joined the forum. I prepared a project and analyzed it, but while taking the drawings, the program does not give all the drawings, for example, it shows a few beams and columns foundation drawings.
"fuatturan":3t0tv2iu" said:
guys, I just joined the forum. I prepared a project and analyzed it, but when I received the drawings, the program does not give all the drawings, for example, it shows a few beams and columns foundation drawing. I need your help, thanks...
Hello, You have sent a project to İde YAPI Technical Service. In this project, you can get the details of all columns and beams. Since the size of the sheet is small, the details are drawn on two sheets. By enlarging the sheet size, column and beam expansions can be drawn on a single sheet. Also, similar floor facility is used in the Beam Extension Settings and Since the floor-main floor is selected, only the beam extensions of the Ground Floor are taken. The reinforcement details of the other floors are also shown on the ground floor. Note: The upper rigid basement floor number was entered incorrectly in the project. Good work.
