Beam dimensioning
denizbayram
Hello. After I get the formwork plan, I have to delete all of them because the dimensions on the beam are mixed with the beam writings.
Hi, You can edit the location of the Beam name and size in "Beam Settings". If your question is the answer, cancel the "name and size together" option in the picture above. Then before importing the mold plan, uncheck "Beam dimensioning" in "Layer Settings/Sketch Details".
Thank you for your interest, Mr. Hakan, but I think I asked the question wrong, I meant the distance measure showing the width of the beam?
That measure is created together with the internal dimensioning. The location of the internal dimensioning depends on the reinforced concrete calculation axes. It is not possible to remove the beam width measure alone, but you can draw reinforced concrete calculation axles yourself, so you have the chance to shift the measure from the beginning.
