Beam deflection problem
smrs
Hello, in the project I added, I see that the 3rd floor ceiling K29 beam gives a deflection error. I couldn't save it even though I tried different, I'm waiting for your suggestions
Hello, When I click the link you added, it gives an error that the file could not be found, the project cannot be downloaded...
There is a 346 cm protrusion in the area of the beam, that area is having difficulty. When Kirşi makes 25/60, deflection saves. (If you make 25/60, the height requirement that does not require TS500 deflection calculation is provided. To have the deflection calculation done by the program, tick "always check the deflection condition" in the beam settings). However, I think why a colon cannot be placed in the 346 cm area, it should be looked at and the carrier system should be reviewed...
