BEAM CONTINUITY
murat mungan
I CAN'T ENSURE THE CONTINUITY OF THE K 110/ K110 / K112 BEAM I SHALL IT AS A SINGLE BEAM BUT THE K 122 AND K 126 BEAMS ARE AUTOMATICALLY SPLIT UP WHEN IT'S FOUND ?
Turn off the "auto-name split objects" option from the toolbar that opens when you enter the beam command. Thus, each beam piece will have the same name and one piece will be processed as a continuous beam in the calculations. If you select these parts in the project you have drawn, enter their properties and give the same name, you will still reach the same result.
