Beam-column junction
gunner
Hello. In the project I have installed, the bottom floor will be the car park. I cannot connect the columns s01 and s02 to each other with beams due to the ramp to be built with filling inside the building. for the passage of vehicles. I tried to create a frame with the beams on the next floor by giving the s01 and s02 columns an upper elevation of 360 cm. When I looked at the deformation after the analysis, a situation emerged that I circled in black. In the geometry control, an incorrect beam level warning is given. how can i solve this problem? my aim is to calculate the buckling lengths of these columns in both directions correctly. I wonder if I should define s01 and s02 columns at the bottom as free columns without changing the upper levels of the columns in the floor they are located in? I will continue as a normal column on the next floor. ? It's very urgent, I definitely need to clarify this by noon tomorrow at the latest. Thank you in advance for your help.
Hello, define the columns S01 and S02 in the 1st basement without giving an upper level in the 2nd basement. The tops of the columns do not need to be defined as free. The program automatically identifies elements that are not attached to the rigid diaphragm (floor). Good work
