When the basement curtains are formed along the perimeter in the basement and are not marked or marked as rigid in the x and y directions in the floor general settings, the program " The R coefficient controls, irregularity controls such as b1 type, earthquake management They do not participate in the curtain/column shear force controls (calculation of alfas rates according to floors) given in the report. The minimum dimension conditions of the curtain are not taken into account in the geometry control. It may be because it is located throughout the entire structure. Walls that are not located throughout the entire structure will not have an effect on the level of ductility. If you think that your curtain will contribute to the base shear force ratio, do not mark it as a bassinet." Shall I mark "Flood/Curtain that does not continue on all floors" only in the curtain settings of the curtain on the 3rd floor? Or will I mark all of the 1st floor, 2nd floor, 3rd floor curtains? I asked a similar question to this one at
. I would appreciate it if you could reply.
