Basin curtain and floor height
Maksoy
Hello, I have a two-storey building with I=1.5 Floor 130 m2 height 4 m 1st floor 130 m2 height 3 m I need 1.5 m flooding on a raft Do I need to define a separate floor for flooding Or take the 1st floor height as 5.5 m Should I solve it? When I define a separate floor for flooding, the system says the mode is insufficient and does not solve it. When I do not define a separate floor, reinforcement density occurs because the floor height is 5.5. Can you help with what should be?
Hello... You can do it both ways. If you are going to make the curtains independent of the structure later, you may not include them in the system with joints. I haven't seen your system, but if your curtains are turning only the outer contour, define 5.50 if they are like this. It's the same situation if the same shape only rotates under the walls and does not connect the columns. Sometimes we can connect all columns and curtains with these filled curtains. (I usually do this. These curtains support the leveling concrete at the top. Especially if there is an open foundation such as a continuous foundation, you can minimize the collapses. If you are going to build a basement, you can only make a solution with a basement by increasing the number of basement floors. In this case, the basement floor will be divided separately, so the main exit from the foundation You may need to arrange the column, curtain shoots. Good work...
