Basically the stapling problem
Hi, Raft basically to overcome the stapling problem; The thickness of the raft flooring can be increased. If the stapling problem is in the outer columns and there is no amplification, amplification can be done. Concrete class can be increased. Column/curtain size can be increased. Stapling reinforcement can be used in the Column-Curtain Properties/Punching Reinforcements tab... (The drawings of the selected punching rebar are not made automatically. You have to do it yourself by examining the raft stapling report and using the 2D possibilities) You can also review the link below on the subject.
Good work
Mr. Levent, Stapling problems and other problems have been resolved. But I get a cutting safety error on the curtains. When I increase the diameter of the stirrup, the shear force on the curtain increases and the error continues.
"gokhanseker":2hq3s1gv" said:
Mr. Levent, Stapling problems and other problems have been resolved. But I am getting a cutting safety error on curtains. When I increase the diameter of the stirrup, the shear force on the curtain increases and the error continues. /downloads/bd11f34f1c60c5f10ad158fa1a2e0de320200727183153/f11d1e]https://wetransfer.com/downloads/bd11f3 ... 153/f11d1e[/url]
Curtain design shear forces in the project you have added exceeds the limit values allowed in the Regulation TBDY 2018 7.6. .6.3 and item 7.6.7.1 can be reviewed) You can review the explanations about the shear force and possible solutions in the knowledge bank
Good work
In addition, in your project, KA944 and KA969 beams cannot be solved continuously because the viewing direction is not compatible with the beams that should be continuous. It is convenient to change the viewing directions of these beams with the Modify/Beam/Set Basic Object Direction command. Good work
