o_berdibek
hello friends, there is basically a negative tension problem in my project, I saved the system, but it seems like I am making a mistake somewhere, please help
You can upload your project to one of the file sharing sites and then give the link."o_berdibek":k5gesuym" said:I wanted to add the project as a rar file, but I couldn't upload it due to its large size, what can I do
It may not always be possible to recover the negative ground stress due to the earthquake +/- combination. (The x-direction of the structure is quite narrow compared to the y-direction.) In your project, the maximum ground tension was 27.07 t/m2, while the negative tension was around -4.09 t/m2."o_berdibek":39be02hi" said:hello friends, there is a fundamental negative stress problem in my project, I saved the system, but it seems like I am making a mistake somewhere, please help
for the additional reinforcements to change, the main reinforcements must be changed when the calculation axis is changed In your project, the minimum margins meet the reinforcement requirement at the point where the calculation axis no. 1 passes. The minimum marginsage does not meet the calculation reinforcement at the point where the calculation axis no. 2. Move the calculation axis no. 2 to the right so that it does not overlap the columns and walls as in the example project. In this case, the axis will operate at minimum. You will see that the equipment has also changed."o_berdibek":yve5u8sx" said:it was said that there will be changes in the amount of additional reinforcement when the calculation axes are relocated, but in the project, there is no change in the additional reinforcement when the calculation axis is moved, why?
I guess we didn't understand what you were talking about. Can you explain your question with a concrete example? If necessary, you can also establish voice communication.yes, it's already changing. that's what I'm talking about
