Basically I'm getting the error
bagcihan
I drew in idecad 8. Basically I'm getting an error. I drew all 8 demos. There is no error when the ide 7 original of the same project is drawn. The projects are the same, but when drawn at 8, I get insufficient reinforcement error on the base and shear error on 1 beam. I think that the additional reinforcement on the foundation is too much. Can you help me?
Hello, In your project, the upper elevation and elevation values of the P006-P007-P015-P016 curtains on the ground floor are not compatible with the foundation. When these curtains are deleted and 16' rebar diameter is selected for the raft foundation additional reinforcements in the Reinforcement selection dialog and analysis is made, in Ver 8.62 version, there is no warning on the foundation and beam. Notes: -S02 flooring is connected to P019 basement curtain. -You can use the link below about the elevator shaft.
Good work
"bagcihan":dk6pb94o" said:
Thanks, but I got the same error in beam again. It was solved when I assigned 30*60 beams.
In the project I added in my previous message, there is no problem with beams in Ver 8.62 version. Good work
Hello, it gives an error because the additional reinforcements in the raft are not enough. In the reinforcement selection dialog, 22' rebar diameter for raft foundation additional reinforcements is selected and analysis is made, and it does not give an error. Unver ÖZCAN
It gets better when I change the reinforcement, but I passed the same project with 14 gauge reinforcement at ide 7. Why does this increase to 22 in ide 8? Isn't the difference too much?
Hello
"bagcihan":3fu9g8ae" said:
When I change the reinforcement, it gets better, but I passed the same project with 14 equipment in ide 7. Why does this increase to 22 in ide 8. Isn't the difference too much? Various capabilities have been added. You can view it from the link below. 1- Download 2- ideCAD Static 8.62 Click to download In these additions, there may be a slight difference in reinforcement compared to the previous version, which is normal. .) For your information. Unver ÖZCAN
