Hello, no increase is applied for the 1.4G + 1.G combination in the columns due to the earthquake regulation, For 1.4G+1.6Q, N1 value is calculated the same in design and raw results, but there is an exception regarding live load reduction application T498. As a result of live load reduction application, due to the nature of work, 1.4G+1.6Q axial load design value is calculated from raw result. In order for the Vpr value to be calculated larger (in the safe direction), the live load reduction application is not applied in the N1 punching calculation.In this case, you can see the N1 value in the raw results."qwerty":10th7izd" said:Do we get the N1 value in the Basic stapling Calculation from the data in the Raw results section (where the regulation conditions are not applied)?
