BetonArt Yapı
Hello there; Good night, I had a few questions about the foundation compound. Is the "+" or "T" shaped beam junction wrong in Beams in Raft Foundation or Continuous Foundation? I could not find a rule in the regulation about this. Do I create an incorrect state according to the data entry of the program? When I do it in the "+" shape, is it correct to run the beams in both directions, allowing it to split but without creating different elements? Is this question valid for "T" shaped foundations? When I connect the elevator curtains with the foundation continuously and the raft area is small, the stress is high. In this case, would it be wrong to define only the raft with the slab edge without connecting the foundation continuously?
