Basic calculation of overhead line electricity pole
MühendisKUTLU
Hello. How can we make the basic modeling of a 4-leg steel pole with a height of 25 m and a weight of 16 tons, with a cable force of 8 tons at the end? They said that you can accept 10*10 m for the width of the foundation. We do not have the ground information required for the foundation yet. We want to do the modeling first and then continue the work according to the data situation.
In such projects, the electricians give 8 tons as the peak force on the top pole, but if we come to the reason why it is to be enlarged 1.5-2 times, the possibility of factors such as ice load and whipping loads, if we are to come to the basic sizing, if I were you, we would make a tipping calculation and then put the raft on the floor. If it prints 4 columns, I would define small columns and enter the load as axial load in an increased way... you have to determine the safety coefficients yourself because I searched for a while and couldn't find a regulation, take it easy, have a good work
