Hello there; Earthquake code chapter 7 (evaluation and strengthening of existing structures) gives detailed information about performance analysis, but foundations are not mentioned in this section. That is, fundamentals are excluded from performance evaluation. You can follow a path like this in your projects: - if you are adding reinforcement elements and there is no foundation under these elements, you need to add foundation-reinforcement. - or if your existing foundations cannot safely transfer the loads from the superstructure to the ground, that is, if the soil safety stresses are exceeded in your existing foundations, you need to add-reinforce the foundation. - Or if your foundation sections are insufficient, you need to add-reinforce the foundation. For these and similar reasons, you, as the designer, should make the decision regarding the foundations... best regards.
