Basic Advice
leonidass
Hello friends, this is my first project, I am solving a hollow block in an area with h=9.50 in the attached data, I entered the floor height of 3, of course, how should I solve the foundation. that is, even if the foundation is beamed, it should not be thicker than 25 cm. how to solve or urgent help thanks.. regards..
Re: FUNDAMENTAL ADVICE Mr. Leonidass MY SUGGESTIONS 1- You can make a raft foundation without beams and put a flood line up to +50 cm elevation. 2- If you make the reinforcement of the raft foundation beams 16, the TK09 error is removed. You can also choose 14 raft flooring accessories. 3- To avoid the error of relative floor offsets: - thicken the hollow block beams - if not, add a curtain 4- You can put a basement beam on the raft foundation beams up to +50 cm elevation. 5-Check ladder loads and wall loads. 6- Check the roof live loads. 7- Correct the errors in the columns (B). Take it easy Unver ÖZCAN
Re: BASIC ADVICE thanks for your advice.. well now my s1 column (30x60) reinforcement says 20 fi 16, there is a problem but I can't solve it. For a 30x60 column, the maximum I saw would be 10 12. Thank you for your suggestions on how to solve it..
Mr. leonidass Reinforcement is above Purs 2. (Additional: 1) I do not raise Purs to these levels. -3. If you make the suggestion of ": - "thicken the hollow block beams", the situation can be improved.
