Basement floor problem
Hello, For this issue, Mr. H. ŞAHİN's answer 1. You can overcome the problem by arranging reinforcement on floors that exceed the limit in the basement. Arrangements to be made depending on the location of the slab and the supporting conditions, and/or: a) By adding to the relevant slab support b) By making the slab reinforcement type top flat+bottom flat c) By increasing the slab thickness d) By increasing the slab reinforcement or reducing the spacing. Hakan Şahin The project with the corrected flooring is attached. You have a rollover problem. Unver ÖZCAN
"unver":1svbbg89" said:
Hi, Mr. H. ŞAHİN's answer to this problem You can overcome the problem by rebaring the floors beyond the limit in the basement floor 1. Arrangements to be made depending on the location of the floor and the supporting conditions, and It can be done by a) adding to the relevant slab support b) making the slab reinforcement type top flat+bottom flat c) Increasing the slab thickness d) Increasing the slab reinforcement or reducing the spacing Hakan Şahin The project with the corrected slabs is attached. Ünver ÖZCAN
Thank you for your attention, but the problem for the tiles continues, we will follow the instructions you provided and try to solve the problem. Have a nice day.
