basement elevator curtain
trkitaro
Hello, as I mentioned in the title, I could not save only the basement floor elevator curtains. Even though I made the upper floor curtain widths of 25 cm and the basement floor curtain widths of 35 cm, I get cut safety and insufficient reinforcement errors. I would be glad if you could give your opinion on this matter.
Re: BODRUM FLOOR ELEVATOR CURTAIN
"trkitaro":2cgba0q4" said:
Hi, as I mentioned in the title, I could not save the basement elevator curtains only. However, I am getting the error of shear safety and insufficient reinforcement. I would appreciate it if you could provide an opinion and help.
Hello, In your project, the curtains are not modeled as shells. In the curtain properties, select the "model as shell" option for all floors. In this case, curtain cutting safety problems are solved. Good work
