Basement curtains - basement curtain
mehmet2015
Should the curtains marked as basement curtains be connected to the columns because they appear to be connected in the openings. And could this create a short column effect?
Hello Since the basement walls are in the system, they reduce the moments of the columns to which they are connected. Alternatively: 1. You can open the basement curtains one more floor and enter. In this way, you take the tipping moments into account on the full sub-basement. 2. You may not include the basement curtains in the model, so you can solve without considering the basement curtains. In this case, you must leave joint gaps between the sub-basements and the columns during manufacturing. 3. By not connecting the basement curtains to the columns in the model, you may not include the basement curtains in the system by leaving a gap in between. When you enter this way, joint gaps must be left between the basements and the columns during the production in the program You can do as suggested.
Unver ÖZCAN
