Y.E.Zulkadiroglu
Hello, the curtains in the basement lower the AlfaS for the Mixed Building design. It is 0.05 in the basement, but this value is around 0.55 on the ground floor. Now, is it possible to take the ground floor as a basis while designing this building? It is an excerpt from Levent Bey's reply on the forum. "Even though the curtains are modeled as a subfloor, they receive shear force in proportion to their stiffness. And since they are not included in the alfaS control, it is normal for the AlfaS value to be 0.22 at this floor. If you want, you can decide whether to solve a mixed system, regardless of the warning given by the program, according to the AlfaS value on the next floor. Earthquake Regulations In the general report, the AlfaS rates on each floor are printed." Should I only mark elements that have Basement Sheds as Basin Curtains or not? Do you have the possibility to open the definition of sub-basin curtain or non-continuing curtain? Or should I detect it as straight as read? For example, when I continue on all floors on the last floor, but use half-length curtains for elevator equipment, should I mark only that floor?
