Basement curtain slab edge overlap error
unalmh
Hello friends, even though I adjusted the elevation of the basement curtains, I am constantly getting the error that the floor edge on the ground floor overlaps with the geometric control. and when working on the ground floor, the basement perks appear preventing the operation on the ground floor. is there a solution to this? Secondly, the floor on the ground floor is constantly having insufficient reinforcement, and I could not fix it. I will be glad if you help. I uploaded the project. good work
Re: FLOODED CURTAIN FLOOR EDGE OVERFACE ERROR Hello Separate the basement curtains from the column and vertical continuation curtains. (The gap is 2 cm, ensure that it is done by leaving space in the drawing and production.) Change the diameter and spacing of the reinforcement to be sufficient by entering the slab reinforced concrete/additional reinforcement. Unver ÖZCAN
"unalmh":2d1fn54z" said:
Hi guys, even though I adjusted the elevation of the basement curtains, I always get the error that they overlap with the floor edge on the ground floor. The floor on the ground floor is constantly having insufficient reinforcement problem, I couldn't fix it. I would appreciate your help. I uploaded the project. Good work
