Basement curtain in version 6.0053...
Erman Güdü
We downloaded the new update and installed it on our computer. But we could not understand the logic of the sub-basement curtain. The program gives a b2 irregularity error when we increase the basement level as a new floor or the ground floor with a level equal to the height of the basement and make the analysis. Attached is a sample project. If we add a 1m long sub-basement curtain to this project and open it for use here, I think the question marks in everyone's minds will go away. Best regards...
At the moment, it seems that the flooding curtain issue has been solved only in terms of static calculation, but when we look at the vertical drawing of the column, we still see the stirrup tightening as unchanged, right? For now, the r coefficient issue has been settled, I think, millet can be adjusted to the remaining regulations.
basman curtain jeans:0 top jeans:-280, you said, isn't it a mistake? Wasn't our basement curtain 100 cm tall? Otherwise, you can accept that solid as a rigid basement. you said how are we going to accept?
Sorry, I noticed that there is no problem with the elevations. Otherwise, you can accept that solid rigid basement. you said how are we going to accept? I just don't understand the part
