MustafaAkın20
Hello, My first question, I drew the basement and infill curtains on the foundation without defining a separate floor, but when I try to delete some infill curtains, it also erases the floors. There is no problem when I draw one by one by trial and error. I draw the curtain, then if it wipes without upholstery, I leave it. But when these curtains are defined on a single floor, I guess they are interactive with the flooring. Because the D10 slab gave a thickness warning (>12.6 cm) when the basement and infill curtains were not scratched. It did not give a slab thickness warning after infill curtains. I couldn't figure out the logic. In my second question, there is a deflection problem on the 50 cm fringe. I define the connected beams in the console arrow. Do I need to make the fringe parted? There is no indentation, the room does not make sense. Thank you in advance for your support.
