Basement Curtain and Continuous Based System Stair Help!
mrsavas02
Hello friends, I'm drawing a project with 80cm basement curtain and I created a staircase, the problem is that now I created the basement not separately, but combined with the ground quota, and I can't put any filling in that 80 cm gap, neither the floor seems to be a gap, and when I create the stairs, the 80cm lower gap starts from the floor, I How can I fill that gap? below the basement level 0, the end of the basement +0.80 floor 1st floor level +3.65 I am waiting for your help
Re: Basement Curtain and Continuous Foundation System Stair Yard Hello, if a floor that will form a diaphragm in place in the 80 cm subfloor part, you can enter as a separate floor and define the floor. If there will be no diaphragm formation, you can define it as in the project and add details such as filling to the drawings using the program's two-dimensional possibilities. You can adjust the stair level from the stair properties. Notes: -It would be appropriate to select the option 'Basic/curtain that does not continue on all floors' from the properties of the basement curtains on the floors that cannot be considered rigid. -The ductility level mixed system was chosen in the project, but there is no curtain that continues on all floors. I recommend choosing a high ductility level. Good work.
"Emrah YILDIZ":380uqhc2" said:
Hello, if a floor that will form a diaphragm in place in the 80 cm basement area is to be manufactured, you can enter as a separate floor and define the floor. If there will be no diaphragm formation, you can define it as in the project and add details such as filling to the drawings using the program's two-dimensional possibilities.You can adjust the stair level from the stair properties. It would be appropriate to mark it. -The ductility level mixed system was chosen in the project, but there is no curtain continuing on all floors. I suggest you choose high ductility level. Good work.
Sir, what should I choose? basically chosen?
Re: Basement Curtain and Continuous Based System Stair Yard
Sir, what should I choose a15, I think the raft should be chosen on a continuous basis a14 should it be chosen on a continuous basis as I did?
The choices you mentioned should be chosen on a continuous basis. related to the structure of the system. Your base system has nothing to do with them. Since there are only columns in both directions in the project you have added (flood walls do not affect this choice), it would be appropriate to choose A11 in a highly ductile system.
Re: Basement Curtain and Continuous Based System Stair Yard Unrelated to the topic, but as you can see in the analysis, the floors are not visible, how can I open them? Help please
Re: Basement Wall and Continuous Foundation Stairs Yard Press the right button on the perspective screen. Click "Analysis System Display Options" in the menu. In the dialog that appears, select "Tile results" in the "Shell results" tab. If you want to switch from Analysis model to Solid Model. On the perspective screen, select "Solid Model with Border Line" in the right-click menu.
Re: Basement Wall and Continuous Based System Ladder Yard
"YasinTezel":31yidbh8" said:
Hi If you want to examine the tiling results after analysis, right click on the Perspective screen. Click "Analysis System Display Options" in the menu In the dialog that appears, select "Tile results" in the "Shell results" tab. If you want to switch from analysis model to Solid Model. Select "Borderline Solid Model" on the right-click menu on the perspective screen
Thank you for your answer, but I want tiles to appear while in analysis. so I can see the tiling errors but they don't show up
